This command disables the checking of the following TLVs when forming adjacencies: Protocols Supported and IP Interface Address.
| area_name | Specifies the name of the IS-IS router process that should no longer perform the adjacency check. |
| ipv4 | Specifies that the adjacency check should no longer be performed on IPv4 interfaces. |
| ipv6 | Specifies that the adjacency check should no longer be performed on IPv6 interfaces. |
IPv4: Enabled.
IPv6: Enabled.
When adjacency checking is disabled, adjacencies may be formed on interfaces that do not reside on the same subnet or do not support IPv4 (if disabled for IPv4) or IPv6 (if disabled for IPv6). If neither ipv4 nor ipv6 is specified, this command applies to IPv4.
The following command directs the IS-IS process named areax to disable adjacency checks on IPv6 interfaces:
disable isis area areax adjacency-check ipv6
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
